Yamaha '84 RZ 250 carbies.Rebuild kits?
I have been searching for ages for away to rebuild a set of 29L carbs off my 250.Can anyone suggest where or how I can find/buy oem or good quality carb parts apart from keyster & cruisinimage?
Its rebuild or buy PWK,s.Any suggestion please?I want to get this bike going again....
Need any leads on after market reeds to.
I also need a set of 65mm o/s pistons for a 350.Wossner or Wiesco?Which is betterer?Will need carbs for this motor aswell, 32mm or 34mm PWK's????
Please help.......
Re: Yamaha '84 RZ 250 carbies.Rebuild kits?
If the 250/350 reeds are the same, you can just get banshee reeds. They are what's in my LC (RZ350 cages). They're carbon and work well.
Hey Steve.
250 cages are smaller than 350.Just found out my best bet is to use vforce reeds for a YZ85!
Main question now is,would pwk28's be too big for a 250?Seeing as though I cant rebuild these 29L 250 carbs...
Who's Steve?
PWK28's should work OK on a 250 with the right jetting. They will be a wee bit big, but should work fine.
