Parts, parts, parts
Parts, parts, parts
I am having a major clear out of parts that I don't need and will never need. They include the following
250LC cigar pipes in good condition
One 31K barrel
One 350 AC head and barrel
One 400 AC head and barrel
DS7 pipes in good condition
400 AC Daytona shape tank with one hole in the side
3 left and 1 right RZ 250 barrels
One set of RZ250 crank cases damaged where the chain came off but oil tight
One 250 AC motor stuck on the bore but complete
2 250 AC bottom ends with good cranks
1 350AC bottom end with good crank
2 sets of 400 AC cases with the same chain damage
About 75% of a DS5
A heap of miscellaneous AC and LC/ RZ and RG parts
I will list more as I get the time. PM me for details on anything and if there is no interest here its ebay.
One 31K barrel
About 75% of a DS5
Re: Parts, parts, parts
PM sent on the 250 cigars
RZ 350 83, tommys, ported, 2nd over, pilots 27.5, mains 280, clip 2 down, r6 shock, acewell spdo, lc radiator.
What does the RD350AC bottom end include, crank cases, gearbox etc?
Eddy
Eddy
Bit of a mix up, the 350 AC is just the crank cases and the crank but I have side covers etc or you can just take a 250 and swop over the gearbox and have two cranks.
Im just chasing some crank cases and a crank primary drive gear, where are you located and how much would you be chasing for them.
I'm in Seven Hills. The cases are no problem, is the gear the same as the 250 if so I have if not its a lucky dip in the box of parts. PM me your number and I will text you a picture.
Email sent regarding the 250LC cigar pipes .
Just been looking at the LC250 pipes and they are two lefts and both have minor defects and a cut and shut of two pipes would be the only way to make a perfect one.
Free to good home before going in the scrap. Likewise the RZ ones.
Pat, dont scrap em... if no one else comes and gets em lemme know and I will come to the "rescue". LOL
Sounds like they have found a home John but if not there yours.
Hi EA police, I will pass on the cigars as freight to Perth was to expensive.
Thankyou. Kind regards Seahorse.
No problem there are a few other foster homes waiting.
Also these KR250 parts that were on ebay last week,
http://www.ebay.com.au/itm/330973925276 ... 1560.l2649
Have a close look at those KR barrels Pat they could be barrels for the Uber rare KVISS system
Never be that lucky Lozza
