2TInstitute wrote:...... engines that 'spin up' faster don't make any more HP, that and light rotors loose rpm as fast as they gain it. Just the thing you don't want for a road bike(or a race bike)
I'm well aware of the characteristics but would disagree with your conclusion " that it is a characteristic you don't want for a road bike (or a race bike)". While I would agree that a balance is needed and that the compromise struck for a street bike would err towards the heavier flywheel, a lighter flywheel (indeed all rotating mass) will change the feel and character of the vehicle and accelerate the vehicle faster.
If the LC needs it or not is another matter. I haven't decided to do it yet but I think it would be an interesting (and cheap?) 'tinker'.
2TInstitute wrote:With the ignition the Yamaha parralel twins run a waisted spark swapping to a 2 pick up 2 coil 1 lobe arrangement with gain 3-4HP alone, but you probably won't fit 2 pick ups in the standard cases.If you continue to run the 1 pick up 2 lobe ignitionyou might get a 1-2HP gain (across the range), big adantage is tailoring your ignition to the engine.
For instance ditched a waisted spark setup , changed to 2 pick ups, 2 coils gained 4-6HP 3ft/lbs torq across the range, even better was
So......
1/Lighter flywheel no change in HP
2/ 2 pick up 2 coil 1 lobe arrangement with gain 3-4HP - but not readily available.
3/ "If you continue to run the 1 pick up 2 lobe ignitionyou might get a 1-2HP gain (across the range), big adantage is tailoring your ignition to the engine."
That is the Zeeltronic ignition with hand held tuner. Bearly noticeable HP improvement but maybe better response and/or fuel consumption with fine tuning??? Maybe better bottom end, top end and/or mid range with better (less compromised fixed timing) ignition tuning?
4/ "For instance ditched a waisted spark setup , changed to 2 pick ups, 2 coils gained 4-6HP 3ft/lbs torq across the range,.."
The best option but not readily available? Is it achievable? Is it easily achievable?
2TInstitute wrote:...... bad had untill 11,500 over rev
I will use mid range on the street and 11,500rpm performance is not on the radar.
