rz steering head bearings
rocet23
Post by rocet23 »
pulled apart steering head bearings because they are notchey,and they are cup and cone type with loose ball bearings.does anybody know the upgraded part number,tappered type and seal part number.hopping to pick them up from abc bearings. thanks john
rocet23
Re: rz steering head bearings
Post by rocet23 »
i got the bearings from bikebiz parramatta $90.00 plus three dollars for the bottom seal.the new bearings are cassed bearings. :fap:
rocet23 wrote:pulled apart steering head bearings because they are notchey,and they are cup and cone type with loose ball bearings.does anybody know the upgraded part number,tappered type and seal part number.hopping to pick them up from abc bearings. thanks john
Measure the steering head stem dia, the steering head dia and the height of the bearing and any bearing shop will get you a replacement for considerably less than $90.
Jeez John, Like I said on the phone... ebay was the way... half price landed from there for bearings plenty good enough :(
rocet23
Post by rocet23 »
yeah you would think so,abc bearings wanted $90.00 for one and $30.00 for the top one.and cbc bearings wasnt much cheaper.must be weird sizes. the top one is 48,25 13.the bottom one is 48od,30id,13height.the one at abc had different seals and would not fit anyway but i think the seal comes out between the cone and bearing.he would not let me open the packet up.yeah ebay is cheaper but needed them to keep plotting on
The mob from NZ that advertise on eBay, pyramid parts are very good. They do full sets seal, race and bearing - even provide a tube of bearing grease to go with it. I've used them for steering bearings, wheel bearings, all types of seals as well without any problem.
DuncanB
Post by DuncanB »
pkay wrote:The mob from NZ that advertise on eBay, pyramid parts are very good. They do full sets seal, race and bearing - even provide a tube of bearing grease to go with it. I've used them for steering bearings, wheel bearings, all types of seals as well without any problem.
I got some dust seals from them for my LC forks and they were absolute shite! Made from some soft floppy rubber... I did get a tube of rubber grease, so it wasn't a complete waste of money! :-|
I wouldn't bet it's rubber grease. Probably raspberry jam with the pips taken out.
Is it just me or do rubber parts always seem to be a quality problem?
Rather worse implications gor brake servicing kits and the like.
Ive had a couple sets of Pyramid bearings now and I won't buy them again.
Did the wheel bearings for the Hybrid and they were noticably notchy from the start, ended up replacing with CBC Japanese bearings and now perfect.
Thats interesting Pete, Ive had lots of them and theyve always been ok. I notcie that the All Balls packaging is the same as the Pyramid Products stuff, so I wonder if they are the same supplier?
DuncanB
Post by DuncanB »
fred99999au wrote:I wouldn't bet it's rubber grease. Probably raspberry jam with the pips taken out.
It did taste rather nice, now you come to mention it!
Any advance on finding out if AllBalls is the same stuff as Pyramid?
I have seen too many negative posts about Pyramid to use them.
