Page 1 of 2
				rz steering head bearings
				Posted: Wed Nov 13, 2013 5:11 pm
				by rocet23
				pulled apart steering head bearings because they are notchey,and they are cup and cone type with loose ball bearings.does anybody know the upgraded part number,tappered type and seal part number.hopping to pick them up from abc bearings.  thanks john
				Re: rz steering head bearings
				Posted: Thu Nov 14, 2013 10:05 am
				by rocet23
				i got the bearings from bikebiz parramatta $90.00 plus three dollars for the bottom seal.the new bearings are cassed bearings.
				Posted: Thu Nov 14, 2013 11:01 pm
				by OzzyElsie
				rocet23 wrote:pulled apart steering head bearings because they are notchey,and they are cup and cone type with loose ball bearings.does anybody know the upgraded part number,tappered type and seal part number.hopping to pick them up from abc bearings.  thanks john
Measure the steering head stem dia, the steering head dia and the height of the bearing and any bearing shop will get you a replacement for considerably less than $90.
				Posted: Fri Nov 15, 2013 11:12 am
				Jeez John, Like I said on the phone... ebay was the way... half price landed from there for bearings plenty good enough
				Posted: Fri Nov 15, 2013 4:05 pm
				by rocet23
				yeah you would think so,abc bearings wanted $90.00 for one and $30.00 for the top one.and cbc bearings wasnt much cheaper.must be weird sizes.     the top one is 48,25 13.the bottom one is 48od,30id,13height.the one at abc had different seals and would not fit anyway but i think the seal comes out between the cone and bearing.he would not let me open the packet up.yeah ebay is cheaper but needed them to keep plotting on
				Posted: Sat Nov 16, 2013 7:49 pm
				by pkay
				The mob from NZ that advertise on eBay, pyramid parts are very good. They do full sets seal, race and bearing - even provide a tube of bearing grease to go with it. I've used them for steering bearings, wheel bearings, all types of seals as well without any problem.
				Posted: Sun Nov 17, 2013 8:27 am
				by DuncanB
				pkay wrote:The mob from NZ that advertise on eBay, pyramid parts are very good. They do full sets seal, race and bearing - even provide a tube of bearing grease to go with it. I've used them for steering bearings, wheel bearings, all types of seals as well without any problem.
I got some dust seals from them for my LC forks and they were absolute shite! Made from some soft floppy rubber... I did get a tube of rubber grease, so it wasn't a complete waste of money!
				Posted: Sun Nov 17, 2013 9:21 am
				by fred99999au
				I wouldn't bet it's rubber grease. Probably raspberry jam with the pips taken out.
				Posted: Sun Nov 17, 2013 1:45 pm
				Lol, variable then... their bearings are fine.
				Posted: Sun Nov 17, 2013 3:54 pm
				Is it just me or do rubber parts always seem to be a quality problem?
				Posted: Sun Nov 17, 2013 6:38 pm
				Rather worse implications gor brake servicing kits and the like.
				Posted: Mon Nov 18, 2013 9:33 am
				by DOC03
				Ive had a couple sets of Pyramid bearings now and I won't buy them again.
Did the wheel bearings for the Hybrid and they were noticably notchy from the start, ended up replacing with CBC Japanese bearings and now perfect.
				Posted: Mon Nov 18, 2013 10:36 am
				Thats interesting Pete, Ive had lots of them and theyve always been ok. I notcie that the All Balls packaging is the same as the Pyramid Products stuff, so I wonder if they are the same supplier?
				Posted: Mon Nov 18, 2013 9:40 pm
				by DuncanB
				fred99999au wrote:I wouldn't bet it's rubber grease. Probably raspberry jam with the pips taken out.
It did taste rather nice, now you come to mention it!
				Posted: Wed Sep 17, 2014 5:21 pm
				by Greasemeup
				Any advance on finding out if AllBalls is the same stuff as Pyramid?
I have seen too many negative posts about Pyramid to use them.
