throttle cable twin carbs
Looking for a part?
Link
Post by Link »
Hi I need a throttle cable for twin mikunis. If someone has a spare. O418383958 Thanks Link
Re: throttle cable twin carbs
Hi Link, cant help with the cable, but I dropped you a PM re cranks in case you havent seen it.
I would think if you dont need an oil line that there are a bunch of easy fit units out there from other bikes, plus this looked useful if you get stuck:
http://www.ebay.co.uk/itm/Venhill-Unive ... 2a3c8b9bee
Have a look at Banshee setups.
I'm using two of them on my 500.
Plenty of them available.
I bought one from Yambits in the UK - cheap as
If you mean like stock cables I got some 2nd spares. Can throw one in with the crank.
Just remove the oil pump cable at the splitter?
Link
Post by Link »
Hi thanks for the help . I ended up with an rz std item but had to mod the plasic block to get it up to 34mm carbs. A bit off the bottom a bit off the top and drilled a bit deeper on the cable grooves. All good now. Thanks
