Premix
tipchap
Premix
Post by tipchap »
hi, i want to run my rg250 on premix. do i need to do anything with the pump?
or can i just disconnect the hose from the oil tank and block the hose.? Paul.
Re: Premix
You probably want to remove it, because if it's like the yamaha ones, it has a piston/plunger inside that will dry up without oil going through it.
