Wanted rz350 parta
Looking for a part?
Stevodude
Wanted rz350 parta
Post by Stevodude »
Hi guys
live in Mackay, beautiful part of the world :-)
I bought a tired old rz350 a while back that I am now trying to get the engine running.
And sad to say, I think one of the barrels has been cooked.
Chasing any rz parts that your would part with?  :-)
Specially a working set of barrels .
Attached is image of piston wall.(left)
I also measured the sizes and they are both 66mm dead on +/- 0.05mm
So here's hoping I can resurrect this baby.
Stephen clarkson.
Left
Right
Re: Wanted rz350 parta
Hi SteveI,
I seen an ad recently on Gumtree out of Tazzie that lists what you need.
Best luck.
GMU..
Stevodude
Post by Stevodude »
Sent some pictures of to the US to see if they want to have a go at boring and plating them, fitting a matching set of pistons. Order some billet power valves, new reeds, carb kit, water pump, water pipes. Haven't even done the crank yet, but most likely will also need a rebuild.
I thing the only thing that will not need doing is the seat is good...
I might let a set of low bore 350 cyls go if you get really stuck, sadly these things are never cheap now :/
