Well, the kH I got of pete is a hum dinger, got it running sweet, which was mainly chuck some fresh fuel in it and give the carb a clean.
But, it has a clutch issue, or the lack of.
Anyone have a manual?
Or a link?
Kh100 service manual
Re: Kh100 service manual
Thommo, I have them. A couple actually.
Plus an original Owners Manual.
Ill shoot you a message.
Pete
Pete
Hi Thommo
Also look up G7 as it's the same bike.
Cable clutch isn't a lot to it. I would dare say you really don't need the manual (I just fixed mine).
Cheers gents, at the end of the day, I think the plates have just stuck from sitting for some time. My tf used be a plick for that.
I had mine apart the other day for the same reason. A mechanic once told me that if you can get if moving stick it an 4th and give it a rev. Of course if it doesn't work the push home is a bitch. I live on the top of a hill so I decided pulling the cover off and cleaning the plates was easier and can check they aren't warped at the same time.
