A – Flywheel rotor. Looks in good order, taper and keyway good, woodruff key included.
B – Magneto stator. Looks good, no visible damage. Mounting screws included. Coil resistances are:
Timing coil W/B-W/R 330Ω
LT ignition coil G/W- B/R 230Ω
Lighting coils Y/R-earth 0.2Ω, W-earth 0.2Ω, B-earth 0Ω
Neutral switch wire Sb between ends 0Ω
C – CDI unit. No visible damage.
D – Rectifier/regulator. No visible damage.
E – Wiring loom. Needs a good clean, a few bullet connectors missing, otherwise looks OK.
F – Control unit. This is the component which decides whether to allow the engine to run based on the position of side stand and neutral switches. No visible damage.
All above parts A to F inclusive $75.
The parts are located in Sydney’s inner west. Inspection and collection by appointment is welcome. Alternatively, I will send them by post at the buyer’s expense (I recommend registered post/COD/tracking etc., but it is the buyer’s choice). Payment by cash is preferred, but postal money order or PayPal will be OK, as long as the buyer pays all charges. Any questions – please ask!
Thanks & regards,
