rdlc clutch hub nut needed
The bottom end I got had no clutch and no nut..I thought they were the same as rz but they are smaller..im held up with out one..thanks
Re: rdlc clutch hub nut needed
dealers can still get em cheap enough i think?
Got it sorted..turns out its the same nut as the sprocket shaft..I had one on the door stop rdAC bottom end I picked up..
