250/350lc exhaust differences??
twinrock101
Post by twinrock101 »
Well as it would turn out i have one 250 and one 350 stock exhaust.. apart from the part number, are they different physically they look to be exactly the same..any help would be great thanks
Re: 250/350lc exhaust differences??
I reckon this may gave been covered on here in the past, would be worth a search. not trying to close down a conversation, and I don't know the answer. Can't really think there'd be a lot of difference but I suspect very minor baffle changes.
twinrock101
Ok thanks..i had tried to google it and search on here..ill dig further thanks
twinrock101
I found waht i was looking for.. even though the part numbers are different on each pipe which was the thrower.. there is a "0" stamped on the back side of the mounting hanger on the exhaust, this will indicate that its a 350 pipe.. as luck would hve it i have the "0" stamped on both pipes ..very lucky considering i bought the both individually..
are you sure both are real 'O's? I ask as people have tried to convince me that spot welds are the o's... if you cannot see a very clear 0 then its not a 350 pipe. not doubting you, just suggesting...
twinrock101
Yep definitely an "0" stamped 10mm below the mounting hole.. one is in perfect condition too no gravel rash the other one has a lil..
youre v lucky to have those pipes then Justin, just enjoy them as they are or sell them to someone who will use em for a resto as they are now quite thin on the ground.
