250/350LC 4L0-01 Carb 4.5mm Brass Balls
Removed the brass balls from my 350LC carbs to clean the air correction circuit. I had to buy 100 balls and used 2. So if anyone needs some PM with your address and I will post.
Re: 250/350LC 4L0-01 Carb 4.5mm Brass Balls
Must be nice to be able to tell people you have brass balls ;-)
Thanks for the offer but I use M5 brass grub screws when replacing the balls, as they are easier to remove next time around. It does mean that you have to run a tap down the passageway and apply a little threadlock but worth it in the longer term imho.
Thought about doing that but in the end went with the balls. They were easy to get out and easier to get back in. I have enough to last another 40 years
