Powervalve flutter
twinrock101
Powervalve flutter
Post by twinrock101 »
Got my rz up and happening and have been riding it.. However it has powervalve chattering.. What is responsible for this.. The servo motor is also very squeaky does not seem to effect performance
Re: Powervalve flutter
pull servo apart and carefully lube the gears, but it could well be the controller.
jools
Post by jools »
Or it could possibly be electrical interference of some sort? That can make servos flutter.
I figured the lube should fix the squeak, do the cables as well tho to be sure, and then go from there.
twinrock101
Pulled it apart it was the catual motor that squeaked.. i swapped the motor with a spare dt200 one i had and lubed all the gears ..very quiet now but there is still the slight stutter..just cant hear it as well now.. power valves work as they should
