RGV Parts - wheels, chain adjusters, triples, rear brake
Got some parts to sell?
Couple of RGV bits I no longer need for my projects:
- Front and rear 17" Wheels - From low kms Japanese Import bike. OEM paint in ok condition, not show winners but not messed with either. Come up as straight on balancer, bearings ok. Bare wheels, ie. no disks, axles, spacers etc. With older tyres fitted. - $500
- cush drive, no rubbers - $75
- Upper triple, one of the underside clip-on bar mounts has been snapped off, only an issue if you wanted to use OEM bars, broken part is underneath so not seen in use, priced accordingly - $50
- Standard RGV cast Iron Lower triple, lock stops in place and all good - $100
- OEM Japanese model (no remote reservoir) rear shock, Grubby but no marks on shaft and bump stop is still in place - $65
- Chain adjusters (complete). rezinc'd bright silver 'cages' and 'bobbins' with new circlips fitted. Expect some marks as these have had a life, but look much better than the rusty junk most bikes have now lol. $40/set of two.
- Swingarm pin, rezinc'd bright silver - $40
- Nice OEM 'side by side' piston type rear caliper body for you to rebuild with new parts, OEM 'grey/black/puriple'ish paintwork with minimal chipping. $75
- Aftermarket used sprocket in good, clean, barely used condition, $30
- I also have some swinger pins and possibly an axle, but they may be VJ21 or GSXR, so let me know what sizes you need and I'll check them.
All plus postage, or come and collect. Pics on request, just email me.
