LC fit and clearances for bodywork
Should the gap between the tank and the left side panel be bigger than the right?
Re: LC fit and clearances for bodywork
This happens when the brackets get punched around in accidents, tho they werent perfect when new. you can move the brackets around with a plastic or rubber mallet but dont go mad.
The brackets look straight, the midsection of the frame looks straight and level, almost like its a “peculiarity” rather than an issue.
LC’s are thin on the ground here.
What do yours look like in this respect Jon?
They are all a bit different, some better than others. Ive adjusted a bit, its only a few mm you can play with tho.
