preparing rd250lc to run premix
pete
Post by pete »
:lol: Hi all.
Just a quick question regarding removal of oil tank/lines and pump from my lc250.I have a blanking plate for the oil pump already,but what about the shaft?......does that just come out,or do i have to do other stuff ?.......also,do i just blank off the carb oil feed lines?......sick of leaky,filthy 2 stroke oil leakin all over my nice garage floor,will hopefully go to premix real soon.Any help much appreciated.
Re: preparing rd250lc to run premix
Remove the shaft and gear from the inside of the engine casing and plug the oil inlet holes in the carbs. If this is on a street bike it will be a pain in the ass mixing premix all the time. I would just get new oil lines and stop the oil leaking on the floor.
pete
Post by pete »
Thanx EPA,i just get a little paranoid at times,30 year old oil pumps,maybe not working.......big bang !!!!........obviously works though,oil on the ground a fair indication.Pump worx,can see lines[clear tubes].Pump gasket[behind pump,has now been replaced[today],may just settle down[me]not the bike.........all is good.
