About to start a NSR 250 MC21 project. Engine is being shipped as I type. Connecting a Ignitech Race as these have gear position sensor already, which should allow mapping in each gear. Have ordered a set of 110mm rods and crank will be going up to graham asap.
Lots of the RS components will fit but I don't think they will be needed.
Look forward to reading what anyone else has done/got up to with their NSR
NSR250
Re: NSR250
I just got an MC18 R5K. All I have done so far is the wire splice, rejet upwards and I have a set of Tyga cans I got for the KR1 but are actually for an NSR. I am going to run it at the Creek as it is and then put the cans on and see the difference.
Re: NSR250
Hi 2T Institute,
Just wondering where you ordered the conrods from?
And who is Graham and how do I contact him?
Cheers, TB.
Cheers, TB.
Re: NSR250
I get the rods and big end bearings from Japan directly. Check the 'dealers' section. Micheal (mixasilen on many forums) can get the centre bearing/seal 40 Euros
Had enough of NSR World ?
Re: NSR250
I have got nothing against NSR-World, except that the moderation is unusually strict and they seem to be a bit biased towards HRC/F3 kit.
Any original new development seems to get shut down somehow. Maybe I'm wrong.
But I just thought I should do my bit to keep them honest and give an alternative place to discuss NSR related stuff that "isn't allowed" on NSR-World.
Hence an alternativeNSR forum
Re: NSR250
That's the truth.
The RS 125 rod from VHM would drop straight into the NSR. I am using a 110mm rod.
I laugh how every second PGM fails but nobody has used a Ignitech and all seem afraid of a programmable ignition
Re: NSR250
Hi Lozza ,
how did the conversion work out ?
Re: NSR250
Mekros is moving from Melbournistan so project could get a kick in the guts soon. Conversion will be a doddle
