Help ME!!!
Smokey
Help ME!!!
Post by Smokey »
Hi,
Haven't posted here in a while, been trying to get the bike going :(
It runs, but then again it doesn't...
The bike had not been ridden for some months.
I have siphoned the fuel out and filled with 10L of shell 98.
It starts fine on choke, but periodically cuts out, if i push choke back in, it will run for a bit then start do drop[ in revs till it dies. if i quickly pull the choke back out the revs lift again.
Now, that said, even if the choke is out it will still eventually drop and die...
I do not know what to do, i have exhausted my knowledge....
It seems that the bike is only running on the right cylinder, but im not 100%
im going to get new plugs and try again...
Any ideas?
Adam
Re: Help ME!!!
Fuel lines or carbs ??
Sounds like spark isnt the issue, but air / fuel mixture.
Clean out both possibly ?
Smokey
Re: Help ME!!!
Post by Smokey »
It seems to be getting fuel,
I drained the float bowls after the last run and there was fuel in there... i might pull the carbies off tomorrow and give them a good clean...
Adam
tomo91
Re: Help ME!!!
Post by tomo91 »
what bike is it i know the rz carbs are annoying for this when the carbs are all gummed up inside, cleaning the pilot jets and a service really helps as the pilot jets are so tiny
Re: Help ME!!!
Clean the carbs, just because there is fuel in there doesnt mean it can get out.
Smokey
Re: Help ME!!!
Post by Smokey »
Well,
It's fixed :)
Took the carbs apart, cleaned them. Replaced the plugs, and re-ran some new fuel lines :)
Runs quite well now :)
However, the right exhaust pipe sounds louder than the left?
What is up with that?
Adam
Re: Help ME!!!
Do you leave it on the side stand all the time, or use the center stand ?
Smokey
Re: Help ME!!!
Post by Smokey »
Side stand. Oil in exhaust? The baffles have been removed as well.
