EOI: Zeel
Got some parts to sell?
EOI: Zeel
Worth a try,anyone interested in a groupy buy?
Link to some info about them,
http://www.zeeltronic.com/page/yamaha.php
Re: EOI: Zeel
Yep I definitely want one :)
Im pretty sure that the Yamaha zeel will work fine on my KTM motor but Ill confirm before we buy.
Re: EOI: Zeel
I need the PCDI-11V
This I believe is also the best ignition for the 350YPVS bikes
So let me know when were going to buy these!
http://www.zeeltronic.com/page/pcdi-11V.php
Technical data:
- minimum revs 200 RPM
- maximum revs 20000 RPM
- minimum supply voltage 8 Volts
- maximum supply voltage 16 Volts
- max. supply voltage for 1 minute 35 Volts
- current draw 25 mAmp
- maximum continuous current for shift light output 1 Amp
- peak current for shift light output 5 Amp
Circuit is protected against reverse supply voltage (wrong connection).
Features:
- CDI charged from hi voltage charging coils (generator)
- programmable ignition map (3D interpolated)
- store and load function for 2 ignition maps
- one input for magnetic pickup
- TPS input (ignition map is 3D interpolated above TPS33%)
- map switch for changing ignition map while riding
- power jet (shift light output)
- quick shift (shift kill)
- tachometer output
- advance/retard whole ignition curve
- three stage rev limit (retard timing, reduced spark, spark off)
- signal delay compensation
- timing calculation for every 1 RPM change (1000, 1002, .. , 9805, 9806, ...)
- programmable power valve actuation
- store and load function for 5 PV curves
- programmable PV deviation
- programmable max close and max open positions
- self PV test on power-up
- PV error detecting (position sensor failure, servo motor failure)
- easy and fast programming on the field, via hand held programmer
- programming while machine running - you can immediately see effects
- monitoring of rev's, TPS position, ignition and PV angle, via LCD(hand held programmer)
- fast processing for high accuracy - delays from 1us
Re: EOI: Zeel
nobody else want one?
Im keen to buy after new years at the latest
Re: EOI: Zeel
Speak to LB Jeram, I reckon two of you could do a deal with someone like Economy Cycle, Aaron and I did as there was a group buy on the rdrz500 forum, there is also a 10% (I think) code you can use as a menber of that forum which would be better n nothing but John will probably cut you a better deal if you can get 5 or more, that's what we did last time.
Sadly i dont any this time round or i would be in, maybe speak to Aaron as he might have another bike on the go soon.
Re: EOI: Zeel
Borut gives me a trade discount the 11V is not PC programmable. An Ignitech is 147Euro and you buy a few of those and cost come down.Your going to use DC/DC on the KTMito Jeram, the 11V is for HV
Re: EOI: Zeel
Lozza, so which one do I need for the KTMito?
Re: EOI: Zeel
I was speaking to DMCC, he said that his ignition (ignitech I think) came with a potentiometer and a basic form of traction control
eg:if engine RPM accellerates past a certain point, the ignition reverts to a retarded ignition map.
plus has map switch.
any idea which ignition that is? because it sounds like one worth getting!
Re: EOI: Zeel
here we go... its the DC-CDIP 2 RACE by Ignitech
what do you reckon lozza?
this almost makes the ignitech a bit better because wheel spin will be a big issue.
quote from the manual...
Switching to the 2nd advance map
- Acceleration threshold: Value of engine acceleration (by how many revolutions per
second) at which the map is switched to "Ignition advance 2". If this function is not
desirable, it is necessary to set a high acceleration value which cannot be reached
(20,000).
Potentiometer - Changes: This is used to select which value will be corrected by the correction
voltage input (correction potentiometer):
1) Off - No operation is executed.
2) Ignition advance - The potentiometer can be used to correct ignition advance
by +/- the value set in the "range" cell (at the bottom).
3) Starting limiter - The potentiometer can be used to correct revolution values
for starting limiters by +/- the value set in the "range" cell (at the bottom).
4) Gear-shift pilot light - The potentiometer can be used to correct revolution
values, from which the gear-shift pilot light will light up by +/- the value set in
5) Switching to the second map - The potentiometer can be used to correct
acceleration threshold by +/- the value set in the "range" cell.
Re: EOI: Zeel
Yeah well Dave hasn't got that right, the potentiometer won't work as basic TC, that is far more complex. The trim pot is only adjusting the advance within a pre-set range.
The Zeel 20V(or another that can be PC programmed) or the plain P2 Ignitech .
Re: EOI: Zeel
yeah, they are two separate functions,
you can use the potentio meter to adjust advance, or shift light or alter the rpm threshold that the TC kicks in at.
but the TC is a completely separate function. well actually I dont think they even refer to it as TC. its just an RPM accelleration activated map switch (aka TC)
I was thinking that this could also be used to retard the ignition in first gear to stop wheel stands and wheel spin, by setting the TC at a rate that comes on in the band at WOT in first gear. then it will also activate in any other gear if wheel spin occurs :)
so does that make it worth getting the RACE ignitech?
it honestly sounds like a ton of fun to set up the TC at a later stage once the bike is running properly
Re: EOI: Zeel
This is why you will rapidly disappear up your own arse chasing this around.
With MotoGP electronics and riders they dial the LEAST amount of TC they can in(fast ones use 3 out of 10 slower ones 4 out of 10).Most times you WANT wheelspin to turn the bike. The Ignitech can only detect wheel spin, if you back the ignition of enough to stop wheelspin when your in a slide = highside.
With a starting curve you want to trigger that by speed or flick a switch just after you get mobile (30-40kmph)
Re: EOI: Zeel
yeah fair call :)
basic zeel or ignitech it is :)
Re: EOI: Zeel
Hey Jeram,
Did you end up buying one?Ill be placing order after xmas.
