Internal stingers
Posted: Thu Jan 10, 2013 9:24 pm
Since I've had new TZMike cans sitting in the garage for years for the LC, I decided I might as well fit them. And if I was going to do that, I might as well do some internal stingers while I'm at it.
I was gonna have Lozza build new pipes for this as well as the 500, but I'll just leave these now and do the 500 when the Mustang is done.
Anyhoo... I got buried in the job and forgot to take progress pics except for this one:
I cut the pipes open because I expanded the end of the stinger inside, so had to slide it through from inside out. This is obviously not a problem if you're building the pipe from scratch.
I used 1inch exhaust pipe, which gave me around a 22.2mm internal diameter (1.6mm wall)
I still need to remove the pipes again to clean them up for paint. Just put them on to hear it.
I used TYGA flanges with the holes drilled slightly bigger to fit the TZMike cans.
The verdict? It's definitely quieter. Not sure if it's because of the TZMike cans, but I doubt it. The 500 is bloody loud with 4 of them on it.
The internal stinger seems to take some of the edge off for sure, and I'll be asking Lozza to do it on the 500 whenever that happens
