bobbyd
Post by bobbyd »
Re: What's standard HP froma 250LC?
'80 35 hp @ 8500 rpm / 3.0m.kg @ 8000 rpm
'83 YPVS 43 hp @ 9500 rpm / 3.4m.kg @ 8500 rpm
'84 YPVS 45 hp @ 9500 rpm / 3.5m.kg @ 9000 rpm
http://www.rd350lc.net/pagePOWER250.htm :D
bobbyd
Re: What's standard HP from a 250LC?
Post by bobbyd »
Antman
Post by Antman »
Ive seen 250's going quicker than 350's around Oran pk, both competant riders.
Beauty about the 250 barrels is that there is more meat on the transfers than the 350..........................so you can do a lot more porting.
bobbyd
Post by bobbyd »
twinrock
Post by twinrock »
i think 40 is pretty good for a 250lc, a tzr250 makes only 45 suposidly and there is a world of difference in engine developement...hpr figures are always confusing tho..and dont think they mean too much..if track time is the concern it can be more about how it makes the power , not just how much
twinrock wrote:i think 40 is pretty good for a 250lc, a tzr250 makes only 45 suposidly and there is a world of difference in engine developement...hpr figures are always confusing tho..and dont think they mean too much..if track time is the concern it can be more about how it makes the power , not just how much
Depends on the rider better riders can handle peakier engines, as they have the balls and ability to ride at 100% ,100% of the time. As we drop down the greasy pole more midrange is needed, think of how a beginer who will only uses the first 20% of throttle.
Most manufacturers quote crank figures, German dynos give figures in which losses are accounted for and added onto the rear wheel figure.
What really matters is the shape of the curve and the area under the line
bobbyd
Post by bobbyd »
It's the greasy pole again the further up you go the more it matters. But even at MotoGP level they still talk about 'midrange'.Go figure :)
A 125 is a purpose built race bike not a converted road bike, while they are 'only' 125cc but they only weight 75kgs.
