RGV SP parts.
Looking for a part?
RGV SP parts.
Need triples,mud guard etc.
Re: RGV SP parts.
Which SP? The only triple tree that was different is the bottom clamp on the 21 which was aluminium instead of steel. VJ22 Sp stuff is only the adjustable forks , dry clutch and clse ratio box. VJ23 is different altogether.
Re: RGV SP parts.
Ah thanks for the clarification Lozza,not up to speed on Suzuki stuff at all.
The forks are the fully adjustable VJ22.
So I need triples etc for a VJ22.
Re: RGV SP parts.
search yahoo japan auctions with google translate ;)
Re: RGV SP parts.
Thanks Jeram,Im trying to deal with translater but no one replying yet....
Need triples to suit fork that are 50mm dia at top clamp & 52 at bottom.Also need an axel to suit & caliper bolts.
Also,anyone know where I can get the outer tubes re-anodised in Newcastle area?Any benefit in TiN coating the sliders?
Re: RGV SP parts.
seaserve is a good middle man for the auctions.
He will handle questions, payment and postage.
Re: RGV SP parts.
L.B. wrote: Need triples to suit fork that are 50mm dia at top clamp & 52 at bottom.Also need an axel to suit & caliper bolts.
All RGV VJ22 stuff, and there are triples n axles on ebay right now... else talk to Deet at RGV spares, tell him I sent you.
{Spanner in works for advanced players}... I found out last week that if you can get a japanese market VJ22A (the A means Japanese) lower triple then it will be alloy... same as the SP OEM. I just got one for my projects, much lighter than the cast original other markets version. :)
