Dyno work.
Forum for Aprilia Two Strokes
Dyno work.
Here's what a little work on the Aprilia can do. Has 12cc straight plug heads, Cougar valves, TYGA pipes and stock cylinders. A Zeeltronic is the cream on the cake.
Re: Dyno work.
Can't use Zeal with post classic racing :)
Re: Dyno work.
Says who?
peet
Re: Dyno work.
Post by peet »
from.
new era rules
Standard parts that may be modified:
• Crankshaft
• Ignition rotor may be lightened.
• Connecting rods
• Cylinder barrels and heads
• Forks internals
• Fuel cap
• Triple clamps
ill read .
igition .roto may be lightend.
it can be very open on how its read
it needs to be open within reason .
im using a bbq tray for as catch try on my1kt race bike wich failed on no bungs . but now need to build better try but only spacee is forward lower fairing & header pipe but if it has 2 bungs & hold liquid its ok
:? :wink:
Re: Dyno work.
Won't touch the rotor :wink:
twinrock
Re: Dyno work.
Post by twinrock »
where did u get the dyno work done?
Re: Dyno work.
I did the work on Graeme Morris' dyno. Graeme is kind enough to leave you alone in there.
