They might cost a bit more than the ebay ones but at least they will fit straight on and look very modern. Also remeber that if you get painted fairings and try to modify them to fit, you may damage the paintwork.
Im pretty sure it should be easy enough to fit the front upper and lower fairing. Looks like i may have to move the sidestand further back though.
The only tricky part I can see will be the tail section, as I have to make it solid yet easily removeable for filling the oil, and since it is a one piece tail, may not be easy...
