Custom throttle cables
Does anyone know somebody who can make custom throttle cables?
When I switch to carbs on my 500, I'm going to need a 1 into 4 throttle cable.
twinrock
Re: Custom throttle cables
Post by twinrock »
hey jeff hows things..with patience u can make your own... cables and splitters should be available from many rep bike shop, a tip is use god solder..i use silver solder very strong
I guess I could use 3 of the 500 type twin cable splitters.
Split into two.. one for each side, then put another splitter on each side to go into 4.
peet
Post by peet »
you could use rg500 lowers cables & rz500 upper & oil cable
had to space out the oil adjuster a bit
was a easy job & lenth worked out to be good
peet
I've made a custom oil cable already because my PV controller is up the front.
Thinking about it again, it will probably be a must that I use the first RZ splitter to include the oil cable so I don't have to change anything there. Then just split again for each side.
CBR600
Post by CBR600 »
general auto cables liverpool 97300487 no web site. ( did my dt200 bigger carb upgrade perfect job however expensive cost 80 bux for 1 cable and i supplyed one of the ends)
shop 2 is
con wire milperra 02 9774 2155
http://www.conwire.com.au/
Vj21. 88
Dt200 1994 power house 2012
http://lnshosting.com
Thanks mate.
