RZ500 Fiche, Service & Tuning Manuals
Re: RZ500 Fiche and Service Manual
8) hybrid
many thaks for your help
wheels999
Post by wheels999 »
I've got the factory tuning guide... did you want that posted as well?
wheels
that would be great if you could
Smokers Day Out
If you email it to hybiepoo (at) hotmail dot com I will upload that too.
wheels999
Post by wheels999 »
hybrid wrote:If you email it to hybiepoo (at) hotmail dot com I will upload that too.
Done.
colin
Re: RZ500 Fiche, Service & Tuning Manuals
Post by colin »
I am having the moderate Yamaha tune done to my bike as we speak here in Canada. The RZ500 factory tune that you guys have on your page. Most people say that we should use TM Mikuni 28m flat slides. I have found flat slides for a great price but was asked if I wanted TM flat slides or TMV flat slides. He mentioned that the TM 28m flat slides were used for four stroke applications not two stroke applications. What should I use for my application.
My application will be the factory tune with jolly motto's or the JL's they look and sound nice to. Help
Thanks :? Colin
If the TMs are jetted right, they should work fine.
Or if he can get keihins, PWK28's are also great.
colin
Post by colin »
hybrid wrote:If the TMs are jetted right, they should work fine.
Thank You I got the TM 28m With the JL's on the way, can you guys sugest a starting point referance the jeting with these carbs and the JL's with the factory tune in the above section.
Thanks again.
Colin :?:
ozgamma
Post by ozgamma »
Just had this done to my RZ500 by Wilson Performance in the US . Will finish bottom end tune and Dyno when it gets to Australia .
Phase III Tune, All ports to WP Custom Specs plus WP added expertise
Cylinders decked
Re-milled heads to attain proper squish clearance and compression
WP Modified and Balanced Wiseco Pistons
WP modified Stock reedcages
WP Modified Stock Intake Manifolds
TDR single petal Hypertension reeds installed
Custom Intake Boot Spacer to facilitate the larger carb bodys
Exhausts enlarged and polished to mirror finish
Both Cranks trued and welded
Stator Back Cover Slotted for Adjustable Timing
Barnett Racing Clutch Kit Installed
Replaced several worn or otherwise damaged screws, nuts and bolts
Replaced every seal, o-ring and gasket that are still available from Yamaha
All parts inspected, cleaned, and reassembled
4-New 34mm VM Mikuni Carbs with Ultimate Flo Optimizers Installed
WP Billet Throttle Cable Assembly
Custom Petcock/Choke Bracket Installed
New Fuel Lines and Routing
UNI-Filter Air Filters Installed
Billet Fairing Bracket Installed
wheels999
Post by wheels999 »
Don't think those links are working anymore...
You're right.. I'll have to find those files again. I didn't even realise they were in a strange directory when I did the last migration.
Links fixed and RDLC added too.
wheels999
Post by wheels999 »
hybrid wrote:Links fixed and RDLC added too.
Links are broken again.
Typos on my part... should be working now.
